My brake adjuster slowly turns when the car is running at a increased RPM. I cant find any reason why it would be doing this. I don't know if it is from the vibration of the car or something esle.I tried putting a set screw through the tube that the brake adjust goes through where the brake adjuster is mounted to the dash board to create drag, this seem to have helped, but it has also made it hard to turn the brake adjuster. Does anyone have any suggestion on what to look for to fix this problem or a better solution. The adjuster is on a Wilwood pedal in a XR1.
