Huge List of Parts/Tools......Cleaning out Garage.......Cheap Prices
***All Parts in good working condition***
Misc
9 quarts Brad Penn Sae 50 Oil $10.00
Plastic hood scoop (carbon fiber look alike) $15.00
10 misc size brake pads, pairs, ALL NEW $5.00
Ultra shield seat belts (July '07) $10.00
5 gallons race fuel $10.00
2 rear brake discs for non floater 9" $5.00
Rear spring buckets for rearend housing..weld on…qty 2 $5.00
Ford 9" drive flange for grand national hub $5.00
Off-Road fog lamps, qty 2 $5.00
14 stock tie rod ends and 4 center links $20.00
Sweet MFG power steering pump..needs pulley $50.00
Gates power steering hose…part #GL10054 $5.00
Flex fan blade…18" w/ 1" fan spacer $10.00
GM steering box for metric car $75.00
Shop Stuff
Heavy Duty Vise $25.00
Buffalo Bench grinder $10.00
Legacy Air hose reel with 3/8" x 75' (NEW) $50.00
Qty 2 Air hose 3/8 x 25 ft $10.00
Manual trailer jack $10.00
Engine Parts
350 block, .030 fresh line bore, w/ new cam bearings and freeze plugs installed, (Ready to build new motor…never raced) $300.00
Used SBC 350 block..040 (Darrel Hoffman machined block) $100.00
2 SBC timing chain covers $5.00
Comp cams valve springs, part #955-16….full set $10.00
Elgin pro stock cam shaft…part #96580 $15.00
Huge assortment of misc gaskets for SBC $5.00
43 misc spark plug wires…MSD, Excel, Taylor $10.00
3 misc carb adapters $15.00
Edelbrock Torker Intake $50.00
Weiand Intake #7546 $70.00
2 stock distributors w/ 1 extra HEI cap $10.00
Assortment of SBC push rods….30+ $5.00
7.8" full set of push rods $5.00
ARP 7.9" full set of push rods Part #CV7900-3 $10.00
Valve Cover oil deflector $5.00
Stud girdles Crane Cams Quick Lock $50.00
Aluminum valve covers $30.00
Set of Dart Iron Eagle Heads 2.02….1.60 (no valves) $250.00
Bolt on Engine Parts
MSD Blaster #3 Coil $5.00
SBC Aluminum Water pump, 5/8 short snout $15.00
SBC Flexplate…part #04326 $10.00
Lightweight Aluminum 10 1/2" stock clutch flywheel…153 tooth $25.00
Stock clutch assembly $40.00
Schoenfield overrail headers for 350….used on impressive sportsman metric car…have been welded to fix small cracks, W//Mufflers $50.00
Schoenfield left side overrail header with muffler (no cracks) $30.00
Schoenfield Crossover Headers with mufflers $100.00
Front Suspension (Metric Car)
Metric upper control arm for bolt in ball joints Aluminum Shaft $20.00
Metric upper control arm for bolt in ball joints Steel Shaft (w/ ball joint) $20.00
Misc tie rods and center links Make Offer
Call or email.........located in Festus, MO
Dave Armstrong
314.808.6472
davarmstrong@gmail.com
