363 SBC Forged Roller Motor, Complete
Sold, Thanks
363 Small Block Chevy forged roller motor, complete. GM 010 block with all ARP studs, bolts and fasteners.
Competition Products all forged internally balanced rotating assembly.
3.562" 4340 Crank, 6" H-Beam rods with 7/16 ARP cap screws, Ross flat top pistons with double spiro locks. File fit plasma rings and King Pro race bearings.
.250 double roller timing set with roller bearing thrust bearing, SFI Fluid Damper and SFI Flex Plate.
Crower 00430 Billet Roller cam with upgraded distributor drive which allows you to run a steel distributor gear. Crane pop-up roller lifters, Trend push rods and Comp Cams springs, locks and retainers. Roller rockers and Probe stud girdle. 1 to 1 aluminum pulleys.
Dart Iron Eagle 49cc heads with angle plugs, professionally ported to increase velocity. Matched Hurricane intake.
Davis (DUI) HEI distributor with with MSD/DUI rev limiter. New taylor wires.
C&S Aerosol Billet Alky Carburetor with BG fuel bypass.
Spare carb build kit and parts, spare Stewart stage 2 pump, and spare DUI cap, rotor and coil.
18 total nights on motor with 1 night on fresh rebuild.
This is a very, very smooth and driveable motor.
$3750
