New Updated Consolidated Parts List
SBC 18 Degree Bowtie Heads setup....matching bowtie intake, Jesel Shaft 1.80 & 2.00 rockers, 2.180 titanium valves, 1.60 steel exhausts...Nice setup...$2800
Butler Right side head rest $20
Howard Stewart Water pumps SBC $50 each
Adams SBC water pumpo $100
Brinn alum flywheel/coupler $150
Afco Steel Jbar $65
Chevelle Lower Arms (3) Rights (1) lefts $50 each
GRT 1 Peice Lowers (1) 17 5/8 and one 18 1/8 LIKE NEW $85 each
GRT gauge panel $65
Woodward Collapsible Steering Shaft (Long) $150
Woodward Collapsible Steering Shaft (Short) $150
Tilton Reverse mount Pedals $225
System one oil filters $50 each
Alum driveshaft 37 1/2 $100
SBC roller cam one race only $200
New Sweet .300 servo $175
Mastersbilt steel complete steering shaft $100
Dry sump belts different lengths $10 each
Butler Built dry sump tank with Oberg $250
Afco gauge panel…WT..OP..FP…$55
Auto Meter 3 ¾ face switch recall tach $100
FSR alum radiator (small has been Zed) $75
15 Gallon fuel cell with cage and weight clamps $125
26 gallon fuel cage 30
1 Mastersbilt midplate $25
1 shaw midplate $25
1 side mount gas pedal $15
2 rayburn panhard bars $40 each
Pair afco 19 inch swing arms $40
1 shaw slider $50
2 modified front rotors 5x4 ¾ pattern $20 each
1 Set RJS purple belts $30
G-Force seat belts cam button style $40
1 Rocket bumper $50
1 Mod 63 inch 5 inch tall black spoiler with ends $25
3 OLD VINTAGE Billy Moyer spoilers off his late models $25 each
1 BSB Hoop pullbar only $30
BSB steel shock mounts $15 each
Alum bolt on shock mounts $15 each
Steel afco brake floaters $20 each
Frankland sprint center QC cover $85
Coleman Lite Wight quick change gears NEW $85 set
UMP Mod Hoosier $40
AR KK704 grooved tire $40
Afco 5 inch 600 spring $20
1 set sbc alum valve covers $50
Valve cover breathers $5 each
Alum 3 ½ pattern brake brakets $25 each
1 used yellow front nose/floopers/filler (complete cap) off moyers car $100
New & used upper control arms. All different lengths $25 new $20 used
2 upper, 2 lower afco low friction balljoints used but good $20 each
1 used Howe low friction upper balljoint bolt in $35
1 Howe balljoint stud $10
Misc rayburn, mastersbilt and $50 each
Used wildwood dynalite brake pads (4 pads for 2 calipers) $20 each set
2 Rayburn pullbars both need top heim $75 each
New late model Tri Y custon craft headers $400
Late Model headers: schoenfeld rayburn $125, used schoenfeld Tri-Y headers $350
Pair winters shockers $75
Bloomquist RR Steel birdcage $125
1 Alum nylon insert birdcage $75
Wilwood masters ¾ & 7/8 $30 each
Wilwood ratchet proportioning valve with alum interior $40
Winters Sprint center quick change: 33/35 alum tube, 4.86 alum spool, gundrilled axles $800
Breather top & bottom $20 and K&N washable units $5 each
Bloomquist 5th Arms $100
Mastersbilt smackdown 5th arm $75
Many QA1 steel shocks rear and fronts $50 each
Many Koni adjustable shocks fronts and rears $50 each $65 with kits
Regular alum threaded afcos: 95, 93, 75-6, 75 & 5th coil shock with kits $65 each
2 New Pro smooth alum shocks A760 $50 each
256-577-3624 or email allennaylor@bellsouth.net
money order accepted as well as paypal
