Choosing new heads?
I am building a new 406 and need to decide what heads to use. I can use some opinions with a reason why you prefer one head versus another. The motor is a forged bottom end with a 650 lift roller. I am going to run alchol in it. Oh ya aluminum 23 degree heads.
Thanks in advance.
I like the Pontiac 867 heads for a 23* mod engine . Very smooth and nice raised runners . I just took a set off my engine would sell them with the jesel shaft rockers . 563 659 1153
If you can spend the money. I would look at these very close.
http://www.mullinsraceengines.com/
AFR is the only way to go if you ask me. Depending one what RPM you want to run and or what size track you are on.
Ok I want to use standard rockers so I need a regular 23 degree head. I was looking at the AFR 227 head. Does anyone have any experience with them? or something similar. This is a stock block motor so Im not going to turn the crap out of it.
The CNC'd AFRs have a good rep, good stuff in them. I think they are stock location runners also. Same goes for the Brodix Track 1 227s and Dart 227s. Really can't go wrong with any of these. I have watched allot of guys win races with all of the heads mentioned above.
My 406 stock block only lastest one season only turned it 7000. I use dart pro heads
