any recomendations on wat front springs i should be running with the impala stub? is 4/4 floated rear suspension. i know some chevelle clips run about 650 lf 600 rf. didnt know if i should be stiffer with the different stub or run the same???
have you talked to Brian I know he has designed the entire front end as a package. He's pretty easy guy to talk to and always helpful.
just putting his lowers on might not get you the resaults you want.he uses rocket lm uppers and a special balljoint package.
