01 MastersBilt dragging the right rail
Our track was especially heavy this week and my 01’ (narrow) Masters was dragging the right rail bad. Wore all the powder coat off and dented the underside after 25 laps. Car was good through the center then really tight on exit. I’m guessing the rail was digging in the track, pulling it to the right. I would think a stiffer RF spring would be the only way to get it up out of the track?
Springs:
LF: 500 RF: 425
LR: 250 RR: 225
J-bar: 8” on frame, at pinion height on rear end
Left: 55.2%
Rear: 53.4%
Bite: 100 lbs
2345 lbs total
Above includes 20ga of fuel & driver (steel block / alum heads, wet sump)
5th coil: 350# spring on 3 shock at 37” from centerline of rear end
Any suggestions? Thanks!
