How do you find the gear ratio in your transmission?
I have the same problem. What about 80 ET BA? didn't see that one on there.
If yours does not have the tag like probably 50% of the trannys used in racing , mark the input shaft and the output shaft. Put tranny in the gear you needing to know, have some one help by turning the output shaft one complete revolution, while you count the revolutions the input shaft turns. Now divide the larger number into the smaller number and this will get you in the ballpark.
Mine is a 4 speed,
the tag reads:
80 EI BA
FOG 9J 07G
On the case by the cover it has:
77ET
7006AA.
still don't see either one. I turned the output and I got about 3 teeth past 2 turns on input shaft, but be nice to have the exact ratio.
It's a 4 speed and thanks for everybodys input.
77et aa is 2.14 second gear
dw--on the drivers side of the main case by the top cover are some more numbers--tell us what they are.
