I have a toyota corolla fwd. It's bone stock and has to stay that way. I run on a 3/8 high banked oval. Anybody got any set up tips. Ex. Air pressure what size tires? I just started anything would be a great help.
I am not sure what your rules are but I can try to help you. I would try to run a 195/60r14 or 195/60r15. Pressure would be LF-26, RF-35, LR -27, RR -33. Also I would air all tires up to the same psi (normally I do 35psi) and measure the outside diameter of each tire. Most tires will not be the same diameter. From there I would try to find a way to get some stagger. Put the smallest tire on the lf and biggest on the rr.
