1 Attachment(s)
Sportmod / Bmod Engine (nice)
358 c.i.d SBC... it Was used in the sportmod / bmod division... Everything is new from intake to oil pan... The only reason I'm selling it is because I'm going back to Amod in 2017...would also make an awesome street engine...
(( Internal parts & cylinder head specs..))
BLOCK- #14093638 GM 1987-1995 four bolt main one piece rear...
CRANKSHAFT- #14088526 GM Performance Parts Nodular iron 3.48 stroke...
CONNECTING RODS-#12495071 GM Performance Parts powdered metal 5.7 length...
PISTONS- #L225640 forged speed-pro flat top four valve relief...
CAMSHAFT- #30120513 lunati.. 521/.307/.106 Mechanical..
VALVE LIFTERS- #70992-16 lunati.. Mechanical ..
OIL PUMP- #m55hv melling..
ROCKER ARMS / PUSH RODS-#rp1418-12 comp cams..
TIMING CHAIN-#3100 comp cams...
CYLINDER HEADS- #pce281.1744 Pro-Comp..
Combustion chamber 64cc intake/exhaust runner 190cc 23 degree..intake valve 1.94 exhaust valve 1.50 stainless steel..angle plug...
(( external parts included))
Water pump..pulleys..belts..P/S pump..fan blade..Harmonic balancer..oil pan..starter..valve covers & breathers..intake manifold w/2bbl adapter..billet distributor..spark plugs & wires..flexplate..Bert coupler...
Only four nights & two full races on this engine... Everything is new other than the block which had $800 in machine work done to it....
$3,000.00 located in Chillicothe,Ohio
740-804-0124
Fastgraphics2008@yahoo.com
Comes as you see it in the pics ..even the stand
Price dropped for the last time!!!! Will sell without all the external bolt on's for $2,000
