Just wondering... looks like the used raised t-stat housing I picked up has two 3/8" NPT openings for those hoses... I think that would mean a -6 AN hose? Am I correct?
on a 604 crate engine we have to deal with 3/8" pipe fittings in the back of the manifold
when using dash 6 lines we only bleed trapped air from the rear of the engine however when we go to dash 8 lines we are able to dissipate some heat from the rear of the cylinder head.
Brad
www.race-1.com
Brad How Much in your opinion does this help cooling
we install them on just about every engine but when a guy is on a tight budget I don't sweat leaving them off
it really does not cool better ---it cools more even with water lines (helps the rear cylinders a bit)
I have never seen a water line kit fix a cooling problem
Brad
www.race-1.com
I decided to use -6...thanks.
-6 is plenty.
Thanks guys... I'm using -6....
My build motor is an edelbrock intake. I think its 3/8 lines in the intake and i just had to get the T stat riser. Do you run a 3/8 NPT to AN adapter? The Lines he used don't look like AN fittings
Well I bought some NOS -6 hose originally used for hydraulic lined but ok for water. Max. temp. 240 F. Going to try push loc fittings. I paid $2.00 for each hose... 24" long.
