mini stock and 2.3 parts cheap!
5 - mastercraft avenger tires and wheels 225/60/14 on 4 lug steel wheels (mustang bolt pattern) SOLD
2.3 spacer/starter plate for between motor and trans - $ 10
15" steering wheel with hex style quick release- $ 15
5 Point seat belts February 08 is on the tag but they are in perfect shape.- sold
19" x 22" aluminum radiator. Had a small hole repaired but has been repaired-$45
3" x 14" K & N air filter with blue pre cover and chrome housing. -$15
45 1/2" stock drive shaft out of a mustang. The large counter weight has been removed -SOLD
Motorcraft 2 barrel carb stock out of the box. -sold
2 - 2.3 stock valve covers - $5 each
1 - 2.3 stock oil pan with side rails -sold
Mesh style window net with spring release (black in color)sold
2 electric fans 1 - 14" , 1- 13" -$10 each
2.3 cam and crank gears (stock) - $ 5
7.5 drum brake rear end with 3.08 gears complete and an extra set of 3.45 gears -sold
10 gallon fuel cell. Homemade steel can with -8 fittings installed NO LEAKS- $20
Ken Huber (314)608-0064
