604 stumbles.. Please HELP!!
we have a factory sealed 604. I have purchased two carbs the latest is 650 cfm from Holley. we are running e85 from ignite . it has been tested so right on 85 . we have changed fuel lines msd boxes. distributor plugs. went to little colder plug for e 85 . replaced switches battery . There really isn't anything we haven't changed. this page is new carb we purchased http://www.holley.com/0-80842HB.. As you can see you can change anything on it . Trust me we have. It is a bad stumble from idle circuit . Restarts and running low is bad. If we run high keep up rpm no issue. Runs good numbers. I been racing for years never had an issue like this . Nothing helps . running a vacum gauge but seems to take a long time for vacum to drop . Has anyone had this experience. I could scream . any help at all would be so grateful . on idle it has almost 20psi vacum Only experience in high hp motors so the vacum is more then i am use to dealing with.
