Austin34471
Ah roll centers. One of all time my favorite quotes is "Roll centers has the biggest (words typed on message boards) to (actual relevance to lap time on the track) ratio of anything in racing"
The "kinematic roll center" diagram that everyone loves to use (intersection of lines drawn from tire contact patch to their respective IC points) is flawed immediately from the get go because: it assumes tires are solid, and it assumes the springing is symmetric. IE, if I put a 10,000lb spring in the RF, where is the roll center? It's right where the tire touches the ground. That's the point that the car will flip over around because the suspension is in-compressible for all intents and purposes (a literal "roll" center)...... kinda like when you are on a bumpstop.
Looking at jacking forces and anti-[roll, squat, dive etc] is important..... kinda.. I wouldn't say calculating it is a good use of time, but knowing how it works is important. All any of those things do is effect the amount of weight transferred elastically (through the springs) vs kinematically (through linkages). It does not effect **how much** weight is transferred.. But, as Mark Bush would say, of a pair of weight receiving springs, the stiffer of the 2 gets the weight first.. and anti-____ can make a suspension act stiffer. As Matt said, lots and lots of things to consider. But as far as priorities I would put roll center location pretty far down on that list.
