So I got my hands on a custom grind cam. Not sure if I should toss it or try it out which is probaly what ill do. Anyways 1/2 mile high banked 425 solid lift rule. Heres the specs that came with it 294 duration and .236 @ 50...430 lift and a .105 lobe center. With my gear set usually turn around 8000. I was searching around alot of the bigger lift cams have a duration in that range but the lobe center dont compare.
What yall guys think?
