Ok. I missed the first race tonight because I couldn't get the scales to come out right. I just got this car too. 04 bms mod. 4 bar. Springs are rf 750 of 650 or 175 rr 225. Lr shock in front spring behind rr is coil over in front. No matter what we did the rr was always heavier by at least 100 lbs. I just can not get any wedge in the car. We've gone over everything 10 times tonight and we can't find an issue. Nothing is touching or binding anywhere. We even went as far as pulling lower a arms to check jacking bolts and plates for a bind. Everything looks like it should. Measured the chassis and it is square(thought it may have been bent) I weigh 290lbs and thought I would have too much wedge but no. We put the car on 2 different scales and the same outcome. Someone told me you are supposed to pull the lr axle out to scale. I didn't do that but would it cause this headache? Any suggestions. I would like to go to a practice session on weds but want the car to be close on the scales. Thanks
