Should both shackles be 90deg. Or does the rr lean more to the rear of the car , 225# lr , 200 rr with 2 inch blocks , my rr leans more to the rear of car .
softer spring on that side, probably why
Your shackles should slightly lean towards the rear of the spring to allow the spring to move freely...
should the leaf eye bolt be in the same holes on the shackles on the rr as they are on the lr or should they be different ? is this just for ride height adj. ? .... thanks...
ride height, wedge bite.
