Duraspark dizzy with TFI I module.
We had to do this when our track outlawed the GM module in a Ford. We set the dist so that we had approx 10* at cranking, 16* at idle and 32 - 36* at 2400 rpm all in. This dist will start to retard as the acceleration rate of the shaft slows down approx 2-4 degrees. The same as the plug in chips that are used with the msd boxes. Helps with top end power. The TFI I module was used for just a couple of years, actually seem to work better than the HEI did. Used an E coil, no resister. There are some ignition wiring diagrams in the technical section at www.powerbyace.com
One very important thing to do with all dist is be sure that the housing is grounded. Don't rely on the block.
