Can anyone give me the correct way to measure birdcage placement on a blue/grey front Rocket, WMF Birdcages, thanks.
Thanks, but the measurement I'm looking for is from the rotor to the shock mount on each side and if the shock mounts are to the inside or outside of the birdcage plate.
OH .. I missed that you aren't running standard Rocket bird cages.
I'll get u a measurement here later
I believe the WMF cages are basically a copy of the TWM cages
Rocket cages are RR 8.25" from outside of rotor to center of shock mount. LR is 8.75"
The shocks mount to the outside of the birdcage plates on each side?
Call Rocket. 304 592 3200. Not something you want to screw up. You may have to call the cage manufacturer if Rocket doesn't sell their cages.
Thanks for the help everyone!
Little things like this drive me nuts. Why can't there be something in the setup book about this? Like a rear end axle length, and a measurement from rotor to 4-link heims, and rotor to shock mount. Obviously this is a crucial measurement, just as crucial as the rest of the numbers listed in their book.
