MSD Ignition Upgrade
The MSDŽIgnition upgrade will allow your box to trigger quicker (Faster Responding!) and draw 1.5 amps less. A typical stock MSDŽIgnition 6al as an example using 12 vdc should pull to 12,000 rpm using 12.5 amps and fall on its face. A typical Upgraded MSDŽIgnition 6al with 12 vdc will pull to 15,900 rpm using 11 amps. Typical performance improvement seen on the track 3 to 5 hundredths per lap or pass. This improvement has been used in all forms of racing; its for the racer looking to Leave Nothing on the Table in the racing program. Before any box is modified it will be bench load tested to confirm its operational status in addition it does provide a baseline for comparison once the upgrades complete. The heart of the upgrade is a matched pair of main amplifiers as well as some associated bias parts to get the best effort from the upgrade. Once completed the MSDŽIgnition box should be 2 to 3 percent faster triggering than a stock unit from the factory. The following MSDŽIgnition boxes can be upgraded 6A, 6T, 6TN, 6AL, 6ALN, 7AL2 and 7AL3. The price 6A $95.00, 6T/TN $100.00, 6AL/ALN $130.00, 7AL-2/AL-3 $150.00. Thank you for looking at the post and if you have any questions please feel to contact me.
