What is the difference in a regular bert bell and the "crate" bell housing and does it change driveshaft length? Thanks in advance
the difference is the flywheel/drive hub that comes with the package
crate engine has a flywheel with a external counter weight and new style bolt pattern
no difference in actual bell housing
Brad
www.race-1.com
Brad is there a spacer and bolt kit made for the ct525 flywheel. Seems a long way off the throw out gear, like 1/4 inch off. Think I have a winters bell.
did you bolt the starter on and then measure?----the starter will move the idler closer to the ring gear
if your bell is winters ---you should be using winters flywheel not BERT
Brad
