After running Saturday nights heat race I noticed the RF tire had very little to no heat in it at all and the RF shock had 2 inches of travel left in it. The track is a low banked 3/8 mile with fairly decent bite. The car was decent in one turn.... a little tight in but horrible off & too tight in and bad off in the other. Running on American racer tires g-60s. Car just isn't getting over on the right side. Here is what I have:
Chevelle clip GRT
Springs
RF 600
LF 600
RR 175
LR 150 (16inch)
Shocks AFCO non-gas
RF 3-8
LF 5-3
RR 4-4
LR 9-2
Pullbar is a one way spring style with a 1200 spring and 20-22 degrees
Bar Angles
LRU 46 at full drop
LRL 30 at full drop
Cant remember the right side at drop.
Trailing the right side bars 1/4 inch.
Bar lengths are
LRU 16
LRL 12
RRU 16 1/4
RRL 12 1/4
I am running on the short brackets but can run a 13 1/2 or 15 inch bottom bar on both sides if needed.
Q/C with j-bar 1 1/4 above pinion & 6 inches higher on the frame.
Side to side is set to GRT specs.
57 % rear
52.5 % left
49 % cross
25-30 lbs bite
All without me and I am approx. 235 lbs
I dont have the exact scale numbers in front of me but the RF was lower than the LF by about 75 lbs.
Using adjustable uppers and both have right at 12 degrees at ride height and all non friction balljoints.
Any help would be appreciated.
