Just bought a set of multifire plug wires and on the box it says to ground cylinder heads??? What’s the deal here. Aren’t the head bolts grounding the heads to the block which is bolted to the frame which in turn is grounded to the battery?
I've heard of this and I'm sure it couldn't hurt, but we haven't done it, but with all the new tech, it will probably help
We had an old friend tell us to do the same. We instantly noticed that the car cranks faster and fires quicker. Ran a short ground cable from the back of the head to the top bolt on the midplate. We ground the powder coat off at the mid plate.
More grounds are more better....
Its a good idea too, we always had trouble burning up coils (canister type) if we didnt ground the engine.
Also, another good idea is to run the main power, and the ground, straight to the battery, with larger wire. Done it this way for years and not to many MSD issues overall.
I've done mine for years cheap insurance you can never have too many grounds.
that's not entirely true ...
https://en.wikipedia.org/wiki/Ground_loop_(electricity)
I ran a ground to the head right before we loaded on Saturday. Definitely cranked faster.
Lots of potential reasons for bad grounds . Powder coating , paint, motor plate and motor mounts not making clean contact to frame. Separate ground to engine helps eliminate most of these. A electrical joint compound at connection points will help with corrosion from washing. Also don't forget about the battery disconnect on negative cable can and do corrode internally from dirt and washing to make another potential problem
