what kind of low drag fans are out there and other item for crate engines? i think i seen lastyear where cv products made the best fan but i cant remember? could you run a electric fan? and for fuel pumps and regulator what psi fuel should you use? read earlyer where people say it makes more power with a high psi pump and regulator then is dose with just a 6-8lb pump? what is the best fuel to run? also heard that ms 109 made crazy power over other vp fuels?
