upper a arm mount location
stock metric, i want to cut the rf stock upper a arm mount(hat)off and use flat stock to replace it. would like to of course lower mount holes and run in line with center line of frame rail. my question is can i also move it out toward the tire,making the a arm shorter? by doing that now my shock end(nut) will be behind the a arm cross shaft and not inside of the triangle of the a arm. it would make my 8 1/2 inch a arm now a 7 inch a arm.... would that mess up the geometry ?
