Going to use a non-beadlock wheel on the right front. Running on high banked tracks and they can get rough. What is the amount of air do i need to keep the tire from rolling off, Thanks
run a beadlock and 14lbs of air, and not worry about it.
you are just asking for the RF to hit a hole and pop the bead. possibly sending you into a wall.
So I have to ask, is the 50-60 bucks you saved on the RF wheel worth it?
all imca cars have no bl on rf, i run anywhere between 14 and 16 psi
Thanks racing kid.
Used 16 lbs. of air last nite....No problems.
Just an update. Been running the RF tire pressure down at 12lbs. for a while now and haven't had a problem yet.
