Does anyone know anything about this
for Mini Stocks? Any information would be
greatly appreciated. Thank You
You need to burn 30 percent more fuel. It isn't as easy as just increasing jet size the passages in the carb need to be opened up as well. I burned E85 last year with a holley 500 and the 2 seasons prior to that I burned E98 with a holley 5200. This year I'm going to try the 5200 with E85. When I first switched to E98 I dynoed my engine on 110 octane race gas and then put the E98 carb on and gained 10 horsepower. I switched to E85 because I was having issues with E98 loading up in the turns. E85 didn't have this issue. Just make sure the carb you use is set up to run E85. Good luck.
Thank You I appreciate the input. D
