Are most 4-bar mod drivers using axle dampeners? Pro's and con's of not using one. Thanks
Most in my area are not using them including us. With one on it will tighten entry some and helps with drop off gas. An oil one you probably lose some forward drive but with a high pressure gas one I don't think it hurts forward. It appears it helps transition to on throttle with the hp gas. I think it also helps on a rough track. JMO and best of luck.
