1 Attachment(s)
(2) Car Street/Outlaw Stock Sellout $22,500
STR Jig-built Mustang Street Stock, Turnkey/race-ready feature winner w/less than 25 nights. Setup for strut or shock ft. Complete AR body (featured on AR Bodies website) w/fiberglass roof, hood, MD3 carbon scoop. Fresh (0 laps) 331ci. SBF, machine work done at Jay (not a nice word)(not a nice word)(not a nice word)(not a nice word)ens, Eagle crank & rods, Mahle pistons, DART heads, Comp cam & lifters, Parker funnel web intake, TCC 2-barrel carb, Carter fuel pump, MSD billet dist, MSD 6AL box, MSD coil & wires. Hamburger's remote oil filter w/all braided lines, KRC PS pump, Denso mini-alternator, FSR radiator, Schoenfield headers, KRC quick release throttle linkage, Lightweight bell, Fresh Brinn trans, MB 9" floater rear, NEW LW & polished 6.50 gear w/ultra-LW spool. Wilwood rotors/calipers, bias adj. & proportioning valve, adj. roller gas pedal, Wilwood brake/clutch pedals/master cyl.(currently setup w/Swartz hand clutch also), Custom valved Bilstein shocks, Eibach springs, 4-corner weight jacks, Sweet collapsable column, steering wheel/quick release hub. Quickcar digital tach/gauges. Butlerbuilt containment seat/Racequip belts, RCI 16 gallon cell. Car is race-ready,needs nothing. Comes w/spares (struts, rotors, etc.) ************************************************** ****************************** **BRAND NEW** STR Jig-Built Metric Street Stock Chassis/Roller. Every brand new part to complete roller (less shocks) CAR IS NOT ASSEMBLED - EVERY PART BRAND NEW & pretty much all of them are still in the boxes. The chassis/cage is complete ft to rear w/mounts, steel firewall/floorpans. Everything is primered & ready to be blasted & powder coated. PEM 9"HD floater housing (new stamp, not a re-claim) w/new axles, hubs, LF bearings, rotors, jigged caliper brkts & trailing arm brkts (LF spherical uppers), spring perches. AFCO Big Bore rear calipers. UMI Performance trailing arms(w/LF spherical bearings). Billet clamp on shock mounts. Bolt on batt. box. RCI blk 16gal cell w/-AN feed, return, vent w/cage mts. UltraShield lightweight long bottom Halo 3 containment seat w/black tweed Stuckey Ent. Covers. Simpson bolt-in camlock harness. Wilwood dual MC/brake pedal assy. Joes billet bias adj., Longacre complete steel brake line kit w/lines, fittings, clamps & braided lines. Wilwood clutch pedal & MC. Coleman adj. billet gas pedal. KRC quick disconnect throttle linkage kit. Sweet Mfg. collapsable column w/AFCO firewall support bearing. Joes lightweight alum. steering wheel w/Sweet Mfg. hub. Sweet 6:1 steering box, steering shaft/joints. AFCO corrected geometry center link & idler arm. New LCA w/LF steel bushings, LF QA1 screw in ball joints. Camaro spindles w/new rotors & LF bearings. 3pc UCA w/LF QA1 screw in ball joints, RF angled ball joint holder. FSR double pass radiator w/Allstar powdercoated shaker, MD3 front bumper. weight jack bolts, LW spring cups. Integra springs. Quickcar complete car wiring kit (batt. cables, starter solenoid, all wiring, etc.) Quickcar 4 gauge panel. Quickcar water pressure gauge w/light kit. Quickcar switch panel. Quickcar batt. disconnect. Quickcar digital tach. MSD 6ALN box. MSD Blaster coil w/ brkt. Rocket style door bar/spiders. Schoenfield headers. ft. & rear motor mounts. Misc. spare metric parts. **$15,000 OBO for Mustang Turnkey and Spares **$8,500 OBO for Mustang Rolling (NO Motor, Trans, & Gear) Driveshaft, Headers, Radiator, Ignition, & Seat Included **$7,900 OBO for Mustang Rolling (As Listed Above) WITHOUT Seat **$13,000 OBO for New Metric Chassis and All Parts **-OR- ** $22,500 FIRM for EVERYTHING I own related to street stocks!! Over $42,000 Invested!! May entertain separating cars, but will NOT part-out!! Buyer must pick up *MAY* consider trades for all-aluminum dirt motors, BIG inch drag motors, turnkey cars, rollers + cash, diesel trucks, or ??? But CASH IS KING!!! Call or text 601-917-44thirty for more pics/information. If
