My Holley fuel pump started pumping out the weep hole...I want to purchase a new pump. I currently have -10 inlet and -8 outlet. Would the Holley 110 GPH Fuel Pump be enough? It maintains a pressure from 6.5-8 psi.
Holley pumps aren't that great (they are known to leak). I'd spend the extra money for a better pump like the a Carter racing pump. This is a good one for a crate motor as it has good flow and the pressure is in the right range: http://www.summitracing.com/parts/CRT-M60969
It comes with the fittings too.
depends on what fuel your running. if its oxygenated or e85 you need a good pump like a cv 2508 so the fuel doesnt eat the diaphram. if its pump gas or race gas the carter pump is ok. you should never run just pump gas always a mix of 50/50
