What type of "traction" device do these have? If pullbar, is it biscuit or spring?
The new Lightnings are setup for Biscuit, and or lift bar.
I run a springbar currently on my 2012 car.
Have also been on the Lightning biscit bar.
Both work very well.
Thanks. I was just wondering if anyone was running the reese bar setup.
the reese bar set up was used years ago on leaf spring cars and after a short while they would break.
We got a couple guys running and winning with reese bars. They are simple.
They run in the same place as a lift bar would.
Thats what ours had. Only difference is i think we just tried a square piece of tubing w/ a nut welded in it and tightened the bolt down on the bar. Like i said couldnt come up with a good way to keep it tight only ran it 2-3nights. It was a new car and we went with something more convetional and ended up being sold before we tried it anymore
just curious, what is a reece bar? where can i find a picture of one? thanks
It's a stabilizer bar that fits into a Reese hitch for towing heavier trailers basically a spring bar.
[QUOTE=powerslide;1590448]Thats what ours had. Only difference is i think we just tried a square piece of tubing w/ a nut welded in it and tightened the bolt down on the bar. Like i said couldnt come up with a good way to keep it tight only ran it 2-3nights. It was a new car and we went with something more convetional and ended up being sold before we tried it anymore[/
Southwest Speed sells a bracket for the front and rear of the reese bar. They also have thier own brand of spring bars.
