Lawson Racing garage clean out
$500: Chevy 350 throttle body short block. Everything but intake, water pump and TBI setup. Pulled from 90 Chevy 1500
$15/each: NEW Camaro inner tie rods, left and right (TR-ES442L and TR-ES443L):
$15: 2" aluminum open carb spacer
$100: Rear end power steering pump with Peterson 5" v-belt pulley
$50: GM OEM aluminum bellhousing. Excellent condition. Looks brand new.
$5: Clamp on caliper bracket, wide GM pattern
$20: Wilwood parts. Two 3/4" master cylinder bodies and parts to a rebuild kit.
10/each: GM HEI caps, internal coils and some rotors
SOLD: $20: LF Rayburn purple spindle. Not bent.
$35: TurboStart 16 volt battery charger. Old style.
$35: Tire wrap. 1500-2000' blue tire wrap. Keep tires clean or liquid prep on tire.
$15/each: Transmission stands
$50: GM 3-speed. Needs to be rebuild. Gears inside are ate up. Cased has also been welded.
$50/set: Wilwood single piston Gm calipers.
SOLD: $20: Champ style oil pan. Came on used motor I bought. Welded up but hasn't leaked in 3 years.
$15: Wilwood master cylinder rebuild kit (complete)
$20: NEW 9" Ford rebuild parts, 2 bearing races M88010, 1 pinion bearing M88048, and seal PT 7044NA
Some pictures can be seen here of some parts: http://www.t17dirtracing.com/?d=forsale
