1 Attachment(s)
2009 and 2010 Victory sportmods
2009 Victory sportmod: this car is turnkey with a 602 crate motor with a custom built carb from Karl Performance, holley high flow fuel pump, aluminum water pump, krc powersteering pump,schoenfeld headers, griffin radiator. 3 speed trans with ace clutch and prc throwout bearing,lightweight bert bellhousing, fastshaft driveshaft, 543 gears. bilstien and qa1 shocks. howe screw in ball joints, outpace steering rods, 22 gal teardrop fuel cell, kirkey 17in seat. eibach springs, pinto spindles, ford 9in floater rearend with adjustable panhard bar mount. roller bearing throttle and willwood brake and clutch pedals body has 1 night on it. car has all the mounts to make it a 4 bar. all bolt on parts and drivetrain were new at the begining of the year. 2010 Victory sportmod: bare chassis with (not a nice word)(not a nice word)(not a nice word)(not a nice word)pit, decking, roof, and brake bias gauge All my spare parts are included. Most of spare parts are NEW i have numerous swedge tubes, 5/8 and 3/4 rod ends,tie rod spacers, panhard bar, idler arms, tie rods,2 spare driveshafts, a bunch of spare springs and shocks, upper and lower ball joints, replaceable studs for the howe upper ball joints, steering box, 2 radiators, brand new 583 gears, axle seals, drive flange caps, numerous left and right spindles, krc power steering pump with remote resivour, extra front and rear bumpers, brake adjuster, front hub bearings and seals, clamp on wieght brackets, extra lead, throwout bearing, brake lines, fuel log, spare headers, axles, spring cups, weight jack bolts, panhard bar mounts for chassis and rearend, chevelle lower control arm, upper control arms (adjustable and non adjustable), 4 extra 3 speed tranmissions, 10-15 spare wheels and tires with mud plugs. im sure there is more. everything goes 17000 or best offer. call or text matt at 701-870-1108
