Sprint Parts For Sale
Maxim-Eagle Scoop Hood New $115 Maxim-Eagle Scoop Hood Used $60Winter's 411 Thermal Coated Rearend $625 6 races since gone throughDMI 486 Lightweight Rearend Titanium & EDM R&P $1400 6 races fron New 0 races since gone throughDMI Ultra-Lite Long Splined Axle 5 races old $425 Is straight SOLDRear Axle nuts $20 a setSaldana wheel wrench $120Nut Smacker Knock off tool $50Misc. 411 Standard Gears $30 ea.Misc. 486 Standard Gears $30 eaMisc. 486 SCS Lightweight Gears $85 ea. (Like New)Misc. USED 30 In. Bars $25 ea.Saldana Radiator $85 Rodeck Alum. Block Standard weight Block Needs Repaired Complete 12 Head Top End SOLDComplete Dart Head (Jones eng.) Top End SOLDEngler All-Pro 286-2 Runner's $825 Engler 16 port Barrel Valve no/lines $175 1 set of Top Engler top Lines $110Wesmar Gear Drive $450Front Cover & Water pump $400Cola 3.800 stroke Crank (Mag. ok) Standard/standard $895Aluminum Oil Pan $200Steel low profile oil pan $185Moose Mag w/Taylor 8 MM wires 70 laps old $785 SOLDMag Tech Mag 6 Races from being gone through $450J&E GB-All-pro Pistons 7-have 8 races 1-new part#218590 $185Magnesium Front Cover $150DRC Mopar Rear Motorplate $125Titanium Bolts4 5/16-2" Button Head Bolts $406 5/16 Button Head Bolts 2-1" 2- 1 1/2" 2- 2 3/4" $604 7/16 1 1/4" New $35 7 7/16 Bolts New 2- 1 3/4" 2- 1 7/8" 2-2" 1- 2 3/4" $80All bolts measured from flange to end15 Wheel center Bolts & Nuts $60Injection Nozzles8 450 Engler $2008 185 Engler $2002 sets 165 Engler $200 a/set2 sets 435 Engler $200 a/setHave a few other sets as wellSchoenfeld Tri-Y Sprint Headers 1 7/8"-2" $425 Like NewSchoenfeld Asphalt Sprint Headers 1 7/8"-2" $220 New Sanders 17"-6" offset $400New Winters Direct mount Front hubs with Rotor $185 SOLDNew Weld Right Front Hub (Just hub) $90New V-mac Right Front Hubs complete $135 ea.New 10 Peice Spacer Kit $55New Ratcheting Turn over tool $175New Red Devil Frt. Pads for Ceramic Rotors $45 a/setNew Car Stands (no wheels) $85New Afco Large Body coil over kits $40 eaNew 13 5/8" New Jacobs Ladder no straps $30New TEAMTECH Tucker Helmet Harness Small $200New Simpson D-cell Size small $200New MPD Torque Tube $170New Afco Shock Canister Mounts $40 ea.Advance Adjustable Gas LR shocks $350 Ea. Have dyno SheetsAdvance Double Adjustable Gas RR shocks $550 Ea. Have Dyno SheetsAfco Adjustable Gas Shocks Fronts rebound adjustable Rears Double Adjustable $675Pro 9" Straight 4 $85Pro Shocks 8" $65 ea2- Straight 52- 4-71 4-6Afco 8" $100 ea.168516841683-833 Gallon Saldana Outlaw Tank & Bladder 6 races old w/spare shell $12003 Short Fuel Lilters -12 fittings w/stainless element $30 ea.Maxim 53" Non wing Front Axle $150 SOLDRed Devil 53" Front axles $135 ea.New 53" Coil Over Front Axle $13053" Coil Over Front Axle $75Kinsler 2 5/8" XL Injection light weight barrel valve & lines $900 W/New Outlaw Torque Stacks & Kinser Air Filter $1400Kinsler 2 1/2" Injection Complete With Stacks & Filters Set up to Run Up & Down Nozzles $875Red Devil front Hubs Low friction bearings & Titanium studs 1 race old $395 SOLDWeld Front hubs & Sanders Spindels $275Red Devil Front Spindels $265Red Devil Front Spindels 1 race old SOLDRed Devil Front Hubs 1 Race Old SOLDDMI Black Widow LF Hub & Spindel w/ Brake Rotor $205Red Devil Front Spindle $145Red Devil Front Spindle Titanium Snout $190Red Devil Lf Combo Arms $50 ea.Red Devil Rf Arms $30 eaKingpins $20 a set14" Jacobs Ladder with straps $20Weld 15-15 5 off Outer Beadlock Has a dent in wheel was ran this way no problem $150Weld 18-3 off $235Weld 17-6 off $235Sander 15-15 5 off Outer Beadlock $185PBS Torsion Bar Reamer $185Knee guards $55NEW Hoosier's Tires 2 90-14-15 D-10 $180 ea.2 92-15-15 D-12 $180 ea.1 94-14-15 D-10 $1801 96-14-15 D-10 $1801 98-14-15 RD-12 $1801 100-13-15 RD-12 $1753 DT 3's $165 ea.American Racers3 26.0-8-15 SD35-38 $125 ea.2 28.5-15-15 SD-23 $100 SOLD1 29.0-15-15 SD-23 $100 SOLD1 30.0-15-15 SD-23 $100 SOLD2 MC 3's $125 ea.USED Hoosier TiresFront $65DT 3's $90 Hot lapped only can still see nubs on tires94&96 LR's $60 ea.2 Medium Compound RR's $30 ea.American RacerLr's $25 ea Most just hot lapped Have 2 leftWill be adding more in a few daysIf it fits a Sprint Car I have atleast 1 or 2 laying around the shop Have other Misc. Parts E-mail for any other parts looking for.Located just south of Indy. Can e-mail pictures of all Itemsdrcsprt51@yahoo.com or 414-350-9970
do you have a tel tach for sale
