Holley carb help
I know there's lots of info on previous post's and I couldn't find much clear info. I'm looking for a base line starting spot to set up my holley 4412ct, carb jets power valve and accelorator pump, The motor is s ford 2.3 ranger long rod .460 solid lift cam. Block is decked to 0, and the head is milled to the minimum thickness of 3.725 per rules Any help would be appreciated
73 jets, 3.5 power valve, #28 nozzle, Red cam on #1 position, and .125 size holes in blades
OK thanks! Also what would be the best air fuel mixture for the most power?
