1 Attachment(s)
FOR SALE! 2016 XR1 Rocket
FOR SALE - 2016 XR1 - William Bray (616) 490-4856Parts listFront susp. 1. spindles 2. lowers one piece w/ moog 1005 ball joint 3. uppers howe bearing w/ howe ball joints 4. sweet rack & pinion 4” 5. tie rods rf steel 6. brake calipers NDL 7. hubs wilwood starlite 8. rotors 1 1/4 willwood str. Vane Drivers compartment1. callapsible steering column 2. wilwood pedals and master cylinders 3. quick car gauges op, wt, ot, fp, & tachRear susp. 1. Winters quickchange 2. rocket XR1 birdcages 3. XR1 lift bar 4. XR1 pinion plate 5. XR1 j-bar 6. adj. frame j-bar mnt. 7. brake calipers NDL 8. hubs wilwood starlite 9. rotors 1 1/4 wilwood str. Vane 10. XR1 drop limiter Shocks 1. 3 dbl. adj intregra canister XR1 valving 2. 1 IDA dbl. adj. XR1 valving 3. 1 std. rebound adj. 5th coil 4. 1 LR frt. Std. comp. adj.Fuel cell XR1 design w/ ethanol bladderBody complete with XR1 brace kit
