First time scaling my car.
We recently got scales and set up the car took the car to the track and it handled horribly. It had a very bad push on the tacky tried throwing it in changed bias to all rear nothing helped. During the main it still had a push not as bad but on throttle coming out of the turn the car was super loose basically wanting to spin on the front straightaway I was running maybe 3/8 throttle most of the night just to keep it under control. The car worked good before scaling although we only had a few races in it it was always drive-able both on tacky and slick of and coarse I didn't record any weights before I started moving things around and I was running on fumes trying to get the car ready for the next day and don't remember what I did we also installed a new engine with a dart block so the engine is about 25lbs heavier then before. These are my numbers one concern I have is my lf is almost 100lbs more than rf. cross: 48.66% left side: 53.04% rear:56.57% Lf- 572lbs 550lb spring 10psi 2"off Rf-468lbs 600lb spring 14psi 2"off Lr- 698LBS 250lb spring 10psi 2"off Rr-658lbs 200lb spring 14psi 3off I was scaling alone so these numbers do not reflect weights with the driver. I'm about 195lbs.Let me know if I need to supply any more info any input is greatly appreciated thanks!
