I need to add 40 pounds to car the drive was 260 and now 220 so where is the best place to place this weight to keep the %s the same. Under driver seat or high on left side where do i need to place this?
same place you lost it lol
between driver and drive shaft.thats a neutral area.
Around the drive shaft loop or in that area.
high for wet track low for dry
thanks for pointing me in the direction i needed ill be puting it on the scales soon.
Find the center of gravity for the car and mount it as close to that as possible. This won't change the precentages.Depending on the rear and left side numbers, it may be mounted around the dash bar, above the transmission.
Mount it beside the driver, to his right.That will be as close to the center of gravity, for a dirt car,as you can get.
Put the car on scales, note the rear %, and the left side %. Get a 20# chunk, lay it on the roof move the weight front to rear until the rear % is the same as you started. Then move it right to left until the left is the same. That is the CG, and will have the least amount of change to the car. Vertical is something to tune with.
To my knowledge, Dave is correct.
The only reason you have to do the raising of the car is to be able to calculate the true CoG height. Most just say your CoG is about the same height as the camshaft and it's close enough.
Another way to do it is take the wheelbase and track of the car. Let's say the wheelbase is 100 inches, and the track is 60 inches (just to make the numbers round). If your percentages say you have 55% left and 58% rear, then your CoG is (100%-55%) x 60 = 27 inches from the center of the left-side track and (100%-58%) x 100 = 42 inches from the rear axle centerline.
Dave's method should give the same result and a lot less math...
When you add lead to the CG, the rear and left % will not change. That proves its in the center of CG. Longacre has that procedure for lifting the car on scales to find the CG height.
http://www.longacreracing.com/articles/art.asp?ARTID=22
Lead should be bolted roughly 16-20" on the race car from the ground. There is a formula for finding CG on your car I block mine up 24 inches but I've heard 14" too, the camshaft in the V8 is a used rough in sometimes but not precise. Low weight for Heavy and Tacky Tracks, A higher Position for slick. You want the weight in a common grouping never in front of the front hubs and never behind the rear axle. Try to get your polar moment in a tight central grouping but still maintain the correct percentages and minimize your weight being at far counteracting ends.
I think you two are discussing different things. One person is concerned w/ the CGH(Center Gravity Height) and the other the CG(Center of Gravity).
Again posting the longacre link
I agree with stock car finding your CG includes lateral and height. If you could suspend your car in a single wire from the side and the top there is one central location that would work to balance both
