When moving the left lower down on the cage to say 5 1/2 from 4 1/2, should you reset your droop load? I made that adjustment tonight and rest it and I couldn’t tell much of a difference
Did you maintain your install pin to pin load?
I am running a single 100lb spring, static load was the same until I adjusted the droop load which in turn would have altered the static load
