Ok need a little help here. We have an 06 Shaw Square Tube Car. This thing will enters good but the car wont rotate in the corner so back in the throttle the car car pushes bad. We run 2 3/8 tracks. One is a fast tight corner high bank track and the other fast medium bank with wide sweeping corners. Set up right now.
Springs Shock and Spring Behind LR
lf 500 rf400
lr 225 rr 250
Shocks Had LR with Spring behind on dummy with 8-0 Shock in front
LF 7-5 RF 3-6
LR 6-3 RR9-4
52% Left
51% Rear 67LBS of Bite We have been taking out rear and bite to try to free it up
50%Cross
LR Floated Brake and RF Brake Off
Bars LR Top is 3rd hole from top RR Top is Top Hole
LR Bottom is 2nd hole from bottom RR Bottom is Top Hole
Last time out I put 11.5 inches of j bar spit in it and it made the car rotate but it seems like it is just masking the real problem. I called shaw and kevin gave me some ideas but they didnt seem to help. Thanks for Reading.
