Crazy tight on Entry, middle and exit (on throttle)
car is a 2012 bwrc and it is crazy tight on entry, heavy track, slick track it doesnt matter, car will not turn unless im at all rear break stabbing them hard and backing the car into the corner (crate)
info
springs 450 lf, 275 w/600lb bump spring rf, 225 lr, 250 rr 5th arm is a stack 400/400 w/lock out that comes in at 2"
scale # 645 lf, 511 rf, 667 lr, 614 rr... 48.2 cross, 54.0 lft, 52.5 rear
4 link rods, left upper down 1 from neutral, lrb up on from neutral, both right sides up one from neutral
6.5" of stagger in rear, 2.5" in front
running a 2" spacer on rr
most lead in the center of car about 5th arm. with exception of 25lbs on drivers door to get percent up
what am i doing wrong here... if you need more info please let me know ill tell you all you need if you can get me pointed back in the right direction
