Dry Sump Pump / Leave on car when not being used
Is there a way I can leave my dry sump pump stack on the car without it being actually used ? I'm going to drop a cheapo LS motor in the car to run some races and I don't want to pull the rear-driven dry sump pump / power steering / fuel pump stack off because I'm going to use the PS and fuel pumps, but I can't run the dry sump pump on this LS setup. Obviously I'm asking if there's a way to configure it so it won't burn up without oil circulating.
Any ideas ?
Thanks !
