What is a good adjustment to free up you car when dragging the brake. Seem like it just want to shove the nose in the center? Thanks!
X2..... Quit dragging brake. Is that what you wanted to know?
Adjust car to free entry. I've found needing to drag the brake helps compensate for too tight on entry.
If the track slows an i let out of the gas without dragging the brake the car will just slide in the center?
Id say a little more roll steer would help. I cut my teeth on 1600's and I would drag the brake all the time but holding throttle and holding brake always kept the car tight for me. If it slicked off real bad I would go to front brake and and scrub the pedal to pull the nose down in the center.
