Are there any gears available for the 7.5 between 3.45 and 3.73?
not unless you go aftermarket
OK, where can I get something aftermarket for a 7.5?
randys ring and pinion
yukon gear
richmond
there are alot of companies out there...but plan on spending $250-$300 for custom gears.
If running second gear, don't forget the various 2nd gear ratios available ot adjust final up or down from the readily available R&P ratios....
Check ebay, you should be able to get the gear and pinion for less than $75 with shipping. There's also a place in Hiram, Ga. Can't remember the name but google "mustang parts Hiram, Ga" and you should find them.
Not entirely true on having to go aftermarket to get a 3:73 rear gear. The Thunderbird Turbo Coupe pre 88 had the 7.5 rear with 3:73 gears stock.
I got a set of 3.73 off ebay for 52 bucks shipped. Not sure what they were out of. It took about two weeks of waiting for some to come up. Good deals can be had if you have time to wait. Never any time in the middle of racing season though.
i have 15 sets of 3.73 gears...both in 7.5" and 8.8"...however...he was asking about a ratio in between 3.45 and 3.73 though
Looks as it will be cheaper to get a 8.8. That way, I can use a 3.55. Found one at the junkyard for $100.00.
