!!!!look!!!! Selling out
For sale : fresh from the machine shop 350 four bolt two piece rear main .030 block... Has new cam bearings & freeze plugs.. It was also clearanced for 3.75 stroke crankshaft.. The line bore & deck were also checked... Ready to assemble.....
NEW eagle cast-steel 3.75 stroke 350 main two piece rear main external balance crankshaft in the box....
#103503750
NEW pro-comp 6" I-beam 5140 .927 2.100 bushed full floating connecting rods in the box....
# pce274.1005
NEW pro-comp .030 coated hyperuetectic flat top two valve relief Pistons for 6" rod .927 full floating in the box....
# pce305.1007
Fresh from the machine shop # 3890462 double hump heads 1.94-1.50 valves new locks & retainers....
Fresh Holley #4412 two barrel carburetor 50cc pump w/new fuel log....
Fresh Holley #7448 two barrel carburetor 30cc pump w/#8 fitting....
KRC power steering pump w/pulley & block mount....#50010000/31415000
PPM rearend limiter....#ppm0270
16ft car trailer double axle 6 lug wheels 72" between fenders has lights & ramps and uses 2" ball....
I listed items with part numbers so you can look them up online....
For pictures & prices send me a PM or text/call
740-804-0124
All items are located in Chillicothe,Ohio
