1/4 mi. Asphalt FWD set-up questions...
Okay, time to ask for some help...
We're having a dificult time getting the car to roll into the turns without a push... From the center off it's way better than the turn in! Right now it has the following corner weights:
LF 744lbs.
RF 595lbs.
LR 353lbs.
RR 465lbs.
Total weight: 2157lbs.
Left weight % = 50.8%
Front weight % = 62.1%
Cross weight % = 44%
LF Camber 0 deg.
RF Camber -2 deg.
LR Camber -3 deg. <--- This should be positive, but it isn't loose, do I still change it?
RR Camber -1 deg.
Front toe = 1/8" out
Rear toe = 1/16" out
LF Caster = +1.5deg.
RF Caster = +2deg.
The car has an open diff, and sits here with the same size tire all the way around the car.
Any ideas?
