2003 Black Front End Rocket w/steel block @ 2400 lbs.
Springs
LF-500
RF-325
LR-200
RR-250
Percentages
Left-54.5 ish
Rear-55
130lbs of bite
J-bar @ 8-1/4
* I'm wondering if I need to drop the wedge?
Springs
LF-500
RF-325
LR-200
RR-250
Percentages
Left-54.5 ish
Rear-55
130lbs of bite
J-bar @ 8-1/4
Dropping the wedge may help.
I would first try lowering the bottom right bar on the chassis or a stiffer LF spring.
If it is just a LITTLE loose on entry you could just try less compression in your RR shock.
Every driver/car/track is different. But if it were me/my car/our track I would drop the bite to 75 and see what it does. Left side % is a little high too. But again that's me.
Your scale # would be helpful & 4 bar locations.# of holes also.
What are track conditions when this loose entry is happening?
With what I know about your deal so far.....
take 250 out of rr and put a 225 there........... I know, just do it!
raise j bar to 8 3/4"-9 1/4 " @ frame,
where is ph bar it compared to pinion centerline?
325 is pretty soft , is it bottoming ?
if its a small flat track you MAY get away with a 325.
2400 # car with steel block, how much and where is the ballast?
sounds like the car is not compressing the rr, a 250 in the rr can be too much to get the transfer to start, you'll know if you lower the rr lower rod and it gets looser in!
depending on the track/conditions, a 375 is a good place to start with the rf spring
big indicator on where to go will be travel on both right side shocks
Don't have the exact scale numbers in front of me at the moment, but they look something like this:
LF-598
RF-499
LR-749
RR-619
Total weight is actually 2465
Driver weighs 235 lbs, which is the reason for the higher left side percentage. 20 gallons of fuel and 60 lbs. of ballast directly in front of fuel cell to achieve rear percentage. No other ballast in the car.
Track conditions are semi slick to slick and this is happening at various tracks. All are 1/4 mile to 4/10 mile in size. There are different degrees of banking at the 3 separate tracks. We are also encountering a push, on the throttle, especially when it's tackier. I'm hoping that fixing the corner entry will help with the exit.
We're using a 12 inch, 325 lbs. spring on the RF with no sign of it bottoming out. All tracks go from semi tacky to slick as the night goes on.
J-bar is mounted in the lowest hole on the rearend side, which is about an inch below the pinion centerline?
4 link bars are as follows:
LRT is in the second of three holes, at times we index down on the birdcage 1/2" to 1"
LRB is usually in the third of five holes, we don't move this much (but have used the second hole up at times)
RRT is in the bottom of three holes
RRB is in the middle of three holes
I would move jbar to 1 hole below pinion, and move right bottom bar down 1 hole, jmo
Do you bottom out the coilover, a zip tie on shaft should show you whats going on there, if crushed, your bottoming, 12" spring should not coilbind.
You shure its not too tight and your sliding it to turn it when its slick?
What is the attitude of the car as it goes thru corner?
Up on bars, down all the way fast when out of gas , toting the lf etc.
I'm going to check the RF shock travel tonight.
I'm braking in a straight line, I don't think I'm sliding the rear to make it turn.
Once I can pick up the throttle, the car drives off the corner just a little snug...when it's slick. It feels like its picking up the LF slightly, while on the throttle, off the corner. Also, It's more of a push, off the corner, when it's tacky. It doesn't seem like it gets up on the bars getting into the corner.
for exit push with grip:
raising rrt up one hole when its tacky should help exit push,if its still pushy lower lr upper 1 hole,
for the loose in problem when slick,
does your car drop down the lr suddenly when you lift?
what are you using/doing with shocks thru night?
how is your lr travel limited (lr front shock or chain,etc)?
how much drop in lr suspension?
i think the simple answer is stay in the gas. If you watch richards and the big guys in the rockets they all trail brake pretty hard rarely lifting, even if someone is beside them. If your driver hasnt tried it, it is a good way to fix problems on entry once on the track.
RF shock has about 1" of travel left, it is not bottoming out.
If its a little loose, increase gas pressure in LF 25-50lbs.
Otherwise, increase LF sring, raise j bar on frame, or lower RR botom rod 2 holes.(if their .5 inch)
if your just alittle loose on entry raise your LF spring to a 550lb or 600lb spring. start with the 550 lb spring and if you need more the go to the 600lb. you could try putting rounds just in your LR if the car doesnt feel like its rolling over good this just helps the car get started easier, according to which shocks you have 8 turns or 16 turns per inch try droping the coil over adjuster down about an inch on LR only. and you said it's a steel block, is the engine raised up an inch.
thanks,
4bangerhotrod
