have modified with speed traanny went to put 6 inch slip yoke in but bottoms out is it hitting the speedo gear? if so can i just remove speedo gear and will that allow it to go in farther
yes take it out i took mine out and put an a rubber expansion plug in hole just to keep the dirt out and the fluid from leaking out
cool hope thats it
does the housing go all the way threw after the gear is taken out
You will need to take the tail shaft out and cut it down on a lathe from the end of the splins in about 2" so the shaft is just smaller then the bottom of the splins i hope that makes sents
thanks for the help we took it out and ground it down worked good thanks
