anyone interested ??
i have a steel block , aluminum 18* headed , titanium valves , jesel shaft rockers , 420 motor . completely freshend and just sitting here . it has eagle crank , eagle rods , comp roller cam and lifters , it is the gm block but bottom half was hardened . motor has brand new je pistons rings , bearings . double roller chain and gears . i no longer run a class that i can use in so it needs to go very very close to complete motor just needs oil pan , pumps ,and carb to run ( currently set for drysump but engine builder say if plate was taken off rear main wet sump would hook right up ) any kind of interest let me know 419-934-5086 thank you
i would take $5,300.00 its just sitting here fresh and ready because i can no longer use it
Ok. I'll see what I can do.
not really a mopar guy sorry . what else you got
