Does anyone out there know of anyone that makes and sells 18* steel heads?? please all the help you have is needed?
RHS did . Dont know if they still do .
I forgot about dart too . G.M. performance also has them in one of there older catalogs .
Thank you for the responses still looking have contacted a couple people thank you.
Be sure and ask about the push rods . Most of them will have to have offset lifters and rockerarm setup . I know there used to be one that 23 degree lifters and rockerarms would work . One reason im saying this is if you are running a solid lift cam might not work and added expence for rockerarm setup .
Do you know what G.M. Head it was I got responses from everyone besides them saying they don't make them anymore
I looked in my 2015 G.M. Performance Catalog and you are right they dont make them anymore . They have 18 degree alum. . Sorry . I know the darts are good . I think that is the one that will run stock 23 degree stuff with very little work .
Well this sucks. We have a good 23degree motor now just have a 18degree motor that has good heads but can't run them due to rules have to b steel.
14 degree pro action should work with the 18degree pistons with minimal work, might have to fly cut them a little bit if they were already close. But finding a set is the hard part, don't believe they are in production anymore.
